Message 11 of 16
Re: Problems switching to Norton online security
Does this link help? See the FAQ ‘Why am I getting Server Errors’
https://www.bt.com/help/security/anti-virus-software/what-is-bt-virus-protect-and-how-do-i-get-it-
Message 12 of 16
Looking at the above link, it appears that you may need to be logged in as Account Manager rather  Account Holder
Message 13 of 16
I have already looked at that page, was not any help as the account is setup as specified. I think it is a BT error causing the problem and they will need to fix it. Thanks for trying.
Message 14 of 16
Hope you get it resolved. It’s so frustrating when the process does not work as it should.
Message 15 of 16
Hi
Sorry to say i still have problems installing the Norton Security, everytime i click on the link on the email sent from BT it just says page not working ??
what should i do ??
Message 16 of 16
Difficult to say based on what you have said. All I can suggest is
1. Make sure your BT login is your email address, not something else. That will prevent the download of Norton software
2. Uninstall previous versions of antivirus software
3. Log into your BT account as account manager not account holder
4. Click on link ‘Manage BT virus protect’
