dt-k
Message 1 of 6
Problems with BT Cloud on Mac after update
Hi there,
I was wondering if anyone could help with a issue I am having with BT Cloud app backing up content, or is anyone else is seeing the same issue.
I have BT Cloud app installed on my Mac, and in the bottom left hand corner of the application (where is tells you the number of files it is backing up) this ALWAYS gets stuck. Now this wasn't really a issue with the old version of the app because I could see the files were being backed up when I checked.
However, with the latest update of the app, this is no longer the case. I have to shutdown and restart the app for it to start backing up the files which defeats the whole point of this cloud service.
There is nothing wrong with my internet connection (BT Infinity 2) and I have more than enough space in the cloud (currently using 14% of 550GB), so what's the issue?
Is there a way to rollback to the previous build of the application because at least that version backed up content?
Thanks,
dt.k
Tags (4)
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: Problems with BT Cloud on Mac after update
Hi dt-k,
Welcome to the forum and thanks for posting, please use the 'contact the mods' link in my forum profile to send in your details and we'll get this looked into further. You can find the link by clicking on my username.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
dt-k
Message 3 of 6
Hi Neil,
Thanks for the response.
As requested, I have send a message using the 'contact the mods' link.
Thanks again,
dt-k
Moderator
Moderator
Message 4 of 6
Thanks dt-k,
I've passed on your details to the Cloud team.
Neil
Kudos”
dt-k
Message 5 of 6
Just to update ...
Issue is still ongoing.
I have done one remote session with one of the Cloud technicians. Currently waiting on a second remote session to take place.
dt-k
dt-k
Message 6 of 6
So I seem to have fixed the issue myself.
For anyone experiencing the same issue, here is what I did.
1. Removed all content from the cloud (yeah, I know. Not ideal).
2. Logged out of all devices from within the BT Cloud application.
3. Quit the BT Cloud application.
4. Uninstalled the BT Cloud application.
5. Downloaded the latest version of the BT Cloud application from the BT website.
6. Turned off my firewall.
7. Re-installed the BT Cloud application.
8. Uploaded my content back to the cloud.
So far, so good. Everything is working as expected.
dt-k
