reevesi2
Message 1 of 2
Problems with BT WiFi app and BT Smart Talk
I can not get the WiFi app to work I can log in manually with my email I'd but this does not work for the app. I also tried to install Smart Talk but it will not run through initial setup. I have wasted weeks trying to get the idiots on the help desk in Puna to sort this out. I am of the opinion that my BT I'd which is a simple string set up 20 years ago is the problem how can I change this to my primary email I'd ?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Problems with BT WiFi app and BT Smart Talk
Hi @reevesi2,
Thanks for posting. I'm sure I can help get the MyBT primary ID sorted for you. Can you drop me over an email with your details? You'll get the contact the moderators link in my pofile.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
