Harks68
Message 21 of 38
Re: BT Parental Controls Unavailable
Hi Daniel still not working
I tried various settings like , light, moderate to no avail
I also tried to block specific websites by entering the URL, even that doesnt work.
Hopefully your team can sort it out soon, I believe in you.
JohnC2
Moderator
Moderator
Message 22 of 38
Hi @Harks68  Thanks for the update and sorry it is still not fixed. I've emailed the team helping @DanielS with this so they can get back on the case and @DanielS  will update you when he is back in the office next week.
Cheers
John
DanielS
Moderator
Moderator
Message 23 of 38
Hi @Harks68,
I called your mobile but missed you tonight.
Can you log into your MyBT and activate Parental Controls for me please? Let me know how you get on please.
DanielS
Harks68
Message 24 of 38
Hi Daniel
I have noticed when i activate parental controls they work when im connected to BT wifi hotspot.
I require parental controls at home on my BT hub.
Parental controls are on
DanielS
Moderator
Moderator
Message 25 of 38
Thank you @Harks68,
That's exactly what my checks show. Can you confirm which router you are using at home for me please? If it's our Home Hub can you factory reset it for me please?
DanielS
Harks68
Message 26 of 38
Hi
Its a BT Smart Hub, I have just factory reset it
DanielS
Moderator
Moderator
Message 27 of 38
Thanks @Harks68,
Have you been able to test Parental Controls since?
DanielS
Harks68
Message 28 of 38
cnn.com and express.co.uk
both are blocked for over a day, they both still are viewable
I have strict parental controls on, and can still view bet365 website
Harks68
Message 29 of 38
Changed parental controls to "light" mode earlier
still nothing
DanielS
Moderator
Moderator
Message 30 of 38
Thanks @Harks68.
I've been speaking with the product manager about your issue today. He is actively investigating it. There are multiple data integrity issues between your online account and our backend systems. I am sorry for the length of time this is taking. They've told me that they hope to have a fix in place midweek.
DanielS
