alexmcwilliams
Message 1 of 20
Re: BT Parental Controls still not available months later
Cannot find the Contact the Mods link.
19 REPLIES 19
Message 2 of 20
Welcome to this user forum.
I have moved your post to this new thread, so you can get personal help from the community or moderators, so please watch this thread for updates.
Moderator contact is by invitation only.
alexmcwilliams
Message 3 of 20
Thank you Keith
I enabled Parental Control - light level and this works on my smartphone and tablet.
BUT I can still access unwanted websites on my main desktop computer.
BT have been looking at this problem for a week now and the last phone call from them was to ask for another few days.
Can anyone else help?
Moderator
Moderator
Message 4 of 20
Hi @alexmcwilliams,
I'm sorry the Parental Controls aren't working for you. If you send me in your details, I'll be able to help you with that.
You can send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Community Manager
Community Manager
Message 5 of 20
Hi @alexmcwilliams I see you're due to be called back this afternoon about this fault.
I'm sorry it's taking us some time to get a fix in place, however the team that's dealing with this case has been following the correct process and relevant steps. I have updated your case with your email, and will check this again on Saturday. If the case is not progressing, I'll take over as discussed.
Community ModeratorStephanie
Kudos”
alexmcwilliams
Message 6 of 20
Thank you
alexmcwilliams
Message 7 of 20
Hi Stephanie
My Parental control was removed and added again and I had to activate it once more.  I did so but unfortunately this did NOT do the trick.  Sites blocked on smartphone but NOT main desktop computer.
Alex
Moderator
Moderator
Message 8 of 20
Hi @alexmcwilliams Thanks for the update and sorry that this has not been fixed for you yet. @StephanieG will be in the office later today and she will investigate this further for you then.
Cheers
John
Community ModeratorJohnC
Kudos”
alexmcwilliams
Message 9 of 20
I'll be at football match. Not be back until after 6pm.
Community Manager
Community Manager
Message 10 of 20
@alexmcwilliams don't worry, enjoy the football 🙂
I have taken over the complaint and contacted the relevant team directly to get to the bottom of this. As soon as I have more information I'll get back to you.
Kudos”
