Hotpot
Newbie
Message 1 of 2
Re: How to disable BT-wifi and BT-wifi-with-fon
BT Wifi with Fon: My router is just 7ft away (2Mtrs) and Wifi with fon from across the street selects on my computer first. My advice: Sue BT for invasion of privacy - that's what I intend to do!
1 REPLY
Moderator
Moderator
Message 2 of 2
Hi @Hotpot and welcome.
Sorry you're having problems opting out. Take a look at Why do my devices keep connecting to BT Wi-fi instead of my BT Hub? Can you let me know if that helps?
Cheers
DavidM
Community ModeratorDavidM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
