Chris_Sav
Message 1 of 26
Re: How to turn off hot spot?
Just got a smart hub2 and halo and spotted BT are still using me as a public hotspot on the band I have turned off.
Cannot see a my packge on myBT now, please advise how to opt out of hotpots on the current menu structure.
25 REPLIES 25
Chris_Sav
Message 2 of 26
I wondered where this had disappeared to!
Further research and have follwed the email instructions in
https://community.bt.com/t5/Broadband-Extras-Apps-from-BT/Smarthub-2-wont-disconnect-from-Wi-Fi-x-an...
Be a shame to cancel the new contract as the kit is good, but I live in an isolated house and do not wish to advertise computer gear.
licquorice
Message 3 of 26
If you live in an isolated house (as I do) you will notice any strangers lurking long before they have had a chance to login to BT wifi.
Unless you completely remove all wifi, you will always 'be advertising computer gear' which I doubt is any sort of problem in itself as I suspect there are extremely few properties that don't have computer gear so is hardly a magnet.
Chris_Sav
Message 4 of 26
Suggestions to help with my desire to turn off BT hotpot that I knew nothing of when I took out this contract a couple of days ago are welcome.
Criticisms of my reasons for not wanting to be a hotspot are irrelevant and a pointless post
garybs29
Recognised Expert
Message 5 of 26
Have you tried following the instructions here? https://www.bt.com/help/broadband/how-do-i-opt-out-of-bt-wi-fi-
Chris_Sav
Message 6 of 26
Tried that but thanks for the suggestion, the link is out of date and defaults to the my product page and navigating from there tends to result in BT trying to sell you something. I did find the opt out once but have never managed to find it again. The same applies to the link on the router broadband status page.
Even if successful it would apparently take a month to turn off what turned on instantaneously. What appears to me to be an effort to make it as difficult as is possible to opt out of as turning off wifi on the router does NOT turn off this hotspot broadcast.
Keith_Beddoe
Message 7 of 26
The only way to guarantee that you would never transmit BT Wifi hotspot, is to use a third party router.
Even if you do manage to turn off the hotspot, it will get enabled again if you have to factory reset the home hub, and you would have to go through the process of enabling it online again, then waiting 24 hours, then disabling again and waiting up to 28 days again.
Keith_Beddoe
Message 8 of 26
Chris_Sav
Message 9 of 26
Thanks Keith.
I'm struggling with this.
I've gone from my own bespoke network on FTTC to my own Draytek hybrid router (but no VOIP) / backbone / access point and bridge to BT Halo 3+ to simplify things for my wife should anything happen to me following a health scare. That so to enable support for a bog standard system and cover us when PSTN finishes.
Under the old system we could access BT Wifi anywhere. So having upgraded to the premium BT offering available to us BT will consider it sulking if I opt out of being a hotspot and, in turn, ban us from accessing other BT hotspots as we have done for the last two years?
Is that what will happen?
imjolly
Message 10 of 26
if you opt out of BTWIFI then it will eventually be turned off on the hub and you will no longer have access to BTWIFI/hotspots when out and about.  however if you do not opt out but use a third party router then obviously you cannot connect to your own BTWIFI but you are still permitted to connect to BTWIFI when out and about
