tarekseda
Message 1 of 13
Re: Parental Controls
Hello, my BT parental controls are unavailable and cannot enable them. please fix. same with web protect. i called customer service 4 times no luck
12 REPLIES 12
Message 2 of 13
You now need to use the MYBT app to get parental controls
tarekseda
Message 3 of 13
Message 4 of 13
Is your app up to date on android or apple as that is now the way to access the parental controls
tarekseda
Message 5 of 13
yes up2date .
Message 6 of 13
when you login to MYBT and see bill. Then scroll down to manage settings then manage security settings check parental controls turned on?
tarekseda
Message 7 of 13
thx, i think bt mods need to interfere
Message 8 of 13
Did you check parental controls were shown as one here I suggested?  Did you restart device after app update
tarekseda
Message 9 of 13
Yes all the above
Moderator
Moderator
Message 10 of 13
Hi @tarekseda and welcome to the community.
I'm sorry you're having problems with the parental controls. It looks like you've done as much as possible at your end so I'll be happy to step in and take a look. I've sent you a private message explaining how you can contact the forum moderation team.
Check here: https://community.bt.com/t5/notes/privatenotespage
Thanks @imjolly for helping out on this.
Cheers
David
