Pjsaund
Message 1 of 4
Re: Smart Hub BT-Fon Hotspot?
Apologies for resurrecting an old thread but I have exactly the same issue - but I can't opt out/in as to opt back in requires me to enter my bt ID which MUST be a btinternet address. Mine isn't so I can't opt in? Help!
3 REPLIES 3
Message 2 of 4
You can do it via MyBT
See Opt in or out of BT Wifi using MyBT
Pjsaund
Message 3 of 4
Tried it. Allows me to opt out, but when opting back in it says 'registration failed - please try later'. It actually does opt me back in to using BT WiFi but fails to configure my HH6 for the hot-spot.
Moderator
Moderator
Message 4 of 4
@Pjsaund it can take up to 30 days for the Hub to start broadcasting the BT Wifi signal after you've opted in.
