simonwien
Message 1 of 6
Re: TV everywhere app error TVE_A931
I am getting the same error message and can't log in to the app yet I know my login details are correct.
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Hi @simonwien,
I'll be able to take a look at this for you. Please can you send me in your details using the "Contact The Mods" link found in my profile?
PaddyB
simonwien
Message 3 of 6
Hi Paddy thank you for your quick reply but where is the contact the moderators in your profile? I read somewhere this had been taken away.
Regards, Simon
Moderator
Moderator
Message 4 of 6
Hi @simonwien,
Check the bio section under my username. It should appear on the top left of the page.
DanielS
Moderator
Moderator
Message 5 of 6
Hi @simonwien,
I'm glad we were able to get this sotred for you. It turns out that the youview box wasn’t aligned to the account which was preventing orders and forcing a new box to be sent. Once we aligned the G5 box to the assets we were able to order the AMC channel which also added the missing assets TV Everywhere, HD and kids and added the everywhere App.
Cheers
David
simonwien
Message 6 of 6
Thank you for your help all seems to be working now
Regards, Simon
