graybag
Message 1 of 1
Re: Update messages
Excuse me if this is the wrong place to ask this.
BT NetProtect Plus Vulnerability Scanner often tells me it has found new updates.
But amongst those is always one for Utorrent,which I use to upload/download from a Private Torrent Tracker BUT the Tracker does not allow newer versions of Utorrent.I've already installed a newer version by mistake and had to remove it and re-install the older one.
Question is - Can I prevent this Update from being offered every time?Is there a way to just say "thank you I do not want a newer version please stop including it,every time,with the other,wanted,Updates"?
                   Thanks for any suggestions.
