Tatcho
Message 1 of 4
Reward Card
I recieved my reward card but on using it I found I had forgotten the pin number. How do I retreive it or get a new one?
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Reward Card
Hi @Tatcho
Thanks for your post and welcome back!
Sorry that you're having problems using your reward card.  If you've forgotten the PIN, you can access it by logging into your online account at www.purecard.com and going to My Details>Security>View PIN.
If you are still experiencing problems, you can call the team on 0344 879 1068.  Opening times are Monday - Friday (09:00-18:00)
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
Tatcho
Message 3 of 4
Re: Reward Card
Hi RobbieMac
Thanks for your help. It seems I was not really paying too much attention to the instructions when I first recieved the card.  My wife wanted to spend the money today but when she asked me for the pin number i said..."What pin number"....!! Then all hell broke loose but I feel sure you know how that goes...!!
Anyway thanks a lot for your help on behalf of my state of mind and my wifes spending habits...........
Cheerio....as before ...."Well done"
Tatcho
Moderator
Moderator
Message 4 of 4
Re: Reward Card
You're welcome @Tatcho Smiley Happy
Kudos”Kudos”
