wibrennan
Message 1 of 2
Scheduled Scans option has disappeared from Virus Protect
Hello,
The Scheduled Scans option has disappeared from my BT Virus Protect. I noticed this today, after a scheduled scan had finished. I've run McAfee Virtual Technician but it says everything is fine. Anyone else have this problem or know what could be going on?
Cheers.
1 REPLY 1
wibrennan
Message 2 of 2
Re: Scheduled Scans option has disappeared from Virus Protect
Aha! It would appear the Scheduled Scans option is still available under the Navigation menu - but has been removed from the Virus and Spyware Proection block, where it also used to show when the next scan was scheduled (but doesn't anymore). Anyway, problem solved, can still schedule scans.
