MacK
Newbie
Message 1 of 15
Smart Hub 2 access control management with MyBT app
The BT Smart Hub 2 now has enhanced parental controls.
From ExpertReviews - "The new Wi-Fi Controls, which can be managed via the MyBT app or via the account settings on a browser, come as standard, for free, on the Smart Hub 2 and give parents or guardians greater control over how much time family members spend online. You will need to update the firmware on your Smart Hub 2, and the MyBT app to access these features. "
Having just upgraded to BT Complete WiFi and received a new hub last week specifically for this feature, it seems the current version of MyBT on Google Play (8.5.7, Updated on Oct 2nd), doesn't contain the new features under the 'Your wi-fi network' menu.
Do I have a router firmware issue, or is the Android MyBT app lagging published functionality?
14 REPLIES 14
Message 2 of 15
Re: Smart Hub 2 access control management with MyBT app
just tried using android 8.5.7 and after logging in and entering hub admin password I can access wireless and set access - using samsung s9+
MacK
Newbie
Message 3 of 15
Thank you. Can I check of this is through the MyBT app, under the 'Your wi-fi network' menu?
I'm on a relatively new Moto G6 running Android 9, and don't have the new access management options available. The  "Advanced Settings"/"BT Access Control" option is still available from the Hub Manager interface, but this is new functionality that seems to be accessible only through the MyBT app.
Message 4 of 15
yes -  then I can see my hub and disc and also 'control wifi access for your devices' and then all devices currently connected and others offline
Andy005
Expert
Message 5 of 15
Hi @MacK
I think that this change came in with the latest Smart Hub 2 firmware update, v0.15.00.06145-BT. If you haven't received this update yet then that's why you can't access the control features through the app.
Distinguished Expert
Message 6 of 15
The access control works from your My Bt app on your Android device.
Go to the My Bt app and go to more. Your will then see the option to manage device access to Wi-fi.
You must, of course, be connected to Wi-fi and not a data connection. It also works for older Android versions.
MacK
Newbie
Message 7 of 15
Thank you for all the responses on this. I've found from Andy005's post that this is a firmware version issue.
Although it was only shipped to me last week, it was on a v0.13.x version. After a factory reset, it's upgraded itself to the v0.15.00.06145BT firmware version.
The MyBT app now shows, under the 'Your wi-fi network' menu, the 'Control wi-fi access for your devices' that I was looking for.
EricW
Newbie
Message 8 of 15
How do you set up access control if you dont have an Android or Apple device?.   we have lots of PC and laptops, even smart TVs but  no tablets or mobile phones?
Surley BT havent created a function on their hub that you cant actually access using devices that are physically connected to it?
Message 9 of 15
Unfortunately, you can't.
I believe the idea is to prevent unauthorised circumvention of the access control by those subject to it.
Message 10 of 15
Easily circumvented by a physical factory reset of course, which makes it pointless.
Before, it still needed someone to known the hub admin password, assuming it had been changed.
