-pd
Message 1 of 1
SmartTalk disables microphone after using keypad
Hi,
Recently I've been experiencing problems with SmartTalk on calls where I'm required to use the keypad to go through menus. After dialing and being connected, when I then use the keypad to select a menu it seems to enable the speaker phone and disable the microphone.
The buttons for both mute and speaker show that they're not selected and pressing them does nothing.
I end up having to hang up on the call as the other end can't hear me.
Running iOS 8.3 and latest SmartTalk.
Any ideas?
Tags (1)
