Durgemeister
Message 1 of 5
Stop Autobackup of USB Devices ?
Hi,
This has been bugging me for a while - When I plug a memory stick, Camera, or anything that Windows recognises as a Mass Storage Device into a USB Port, It Automatically backs-up everything to the computer.
It wouldn't be such a problem if the program used the location I have set for my Files, which because I have just a small SSD for Windows, is on a second - Data - drive. Instead, it sends it to the default Sync Location (i.e. C:\Users\<username>\BT Cloud)
Is there any way of switching off the back-up, and perhaps getting it to send it to the correct sync location ? I've looked on the dashboard, and there isn't anything remotely related (That I can see anyway !).
4 REPLIES 4
pottyperson
Distinguished Guru
Distinguished Guru
Message 2 of 5
Re: Stop Autobackup of USB Devices ?
Various programs (some probably malicious) are offered for download to enable automatic copying of usb devices. Are you sure you haven't inadvertently acquired one?
Keith_Beddoe
Message 3 of 5
Google Backup and Sync works the same way, if you plug in an external USB stick, but it asks you whether you want to backup the contents, it does not do it automatically.
There must be a preference setting on the BT Cloud agent, to alter that option?
Durgemeister
Message 4 of 5
I don't have anything like that on my PC, if I do it is very well hidden !
Durgemeister
Message 5 of 5
Okay, I have solved it now...
... feel a little silly, as it was an Autoplay option. For reference, I typed in "Autoplay" in the Search programs and files box on the Start menu, and changed the preference for Photos and Videos, via the drop-list menus.
Mind you, an important point to make here is that there appears to be a fault in the BT Cloud software, as the option to "Upload to BT Cloud" sends it to the default location for the Sync folders, and not the Sync folders as they are set now, and thus never get uploaded. Maybe this has been overlooked as many have their Photos uploaded via Phone/Tablet software, and Digital cameras often don't need USB to upload these days ?
