C1Rider
Message 1 of 5
Text my pin ???
Android 2.2.
app "stuck" on 3 of 3 text my pin
have received pin and have 2 hours to activate it
entering my number again tells me to try in a hour for another pin
I don't need another pin, I have one  Smiley Mad
Bring back [ press button A or B ]
4 REPLIES 4
Message 2 of 5
Re: Text my pin ???
when I received the pin it was entered automatically on my android S2 - just had to 'continue' - and workedok.  other android posters on smarttalk post had same
somersetbob
Message 3 of 5
Re: Text my pin ???
In my case on my S2 I simply switched to text messages and memorized the pin (four digits even I could manage that 🙂 ). But it may well have worked automatically if I'd waited.
Distinguished Guru
Distinguished Guru
Message 4 of 5
Re: Text my pin ???
Doesn't that page have a Continue option or similar? Can't remember the procedure precisely, but I just carried on regardless from there and found the PIN had been entered automatically as already reported.
C1Rider
Message 5 of 5
Re: Text my pin ???
It's working !!!! Whatever I did wrong last night has now cured itself this morning. I requested another pin and it was automagically put in for me. Cheers all..
