TonY20
Message 1 of 7
'The Jail: 60 days' Series 4 Box Set Episodes not opening on BT TV App
Series 4 Box Set Episodes for 'The Jail: 60 days' will not open on my PC  (using the Windows 7 operating system). 'Help' says that this is due to a 'WP100' problem. I have reinstalled Silverlight as recommended, and have also tried using my Internet Explorer browser, instead of my default Firefox browser without success. Reinstalling the BT TV App was also not successful. My BT TV app. has been working fine on all other programmes on 'Live, 'Catch Up' etc. Have contacted the BT Consumer Fault team, and was told that this problem would be reported. Any help would be appreciated.
6 REPLIES 6
RobbieMac
Moderator
Moderator
Message 2 of 7
Re: 'The Jail: 60 days' Series 4 Box Set Episodes not opening on BT TV App
Hi @TonY20
Welcome to the Community and thanks for your post!
Sorry that you've had problems viewing that box set on the BT TV app.  Is this sorted now or are you still having this issue?  If it's still happening post back and I will get it raised.
Cheers,
Robbie
TonY20
Message 3 of 7
The problem is still present in Series 4 Box Set. I have now tried opening all of the Episodes in Series 4 Box Set. The Episodes 1- 4 will not open, Episodes 5- 10 will open, Episode 11 will not open, Episodes 12- 13 will open, Episode 14 will not open, and Episode 15 will open.
I have re- checked all Series 1- 3 Box Set Episodes, and they all still open satisfactorily.
I have previously uninstalled/ reinstalled Silverlight and the BT TV App, and also tried another browser (Internet Explorer instead of Firefox my default browser) without success.
Thanks for contacting me, and for any solution that can be provided.
RobbieMac
Moderator
Moderator
Message 4 of 7
Hi @TonY20
Thanks for posting back!
I raised this with our TV team and they can replicate what you're seeing.  Thanks very much for highlighting this I really appreciate the time you've taken.  My colleagues are looking into this now to get things sorted out.
Cheers,
Robbie
TonY20
Message 5 of 7
Thanks for your reply.
TonY20
Message 6 of 7
Series 4 Box Set now opening on all 15 Episodes- thanks for you and your colleagues  help on this problem, which is much appreciated.
RobbieMac
Moderator
Moderator
Message 7 of 7
That's awesome - Happy to help out 😁
