carol7
Message 1 of 4
Topping up dongle
Please can someone tell me if a dongle has to be kept topped up or if I can just use it occasionally. I only want to use it when I go away.
Carol7
3 REPLIES 3
Community Manager
Community Manager
Message 2 of 4
Re: Topping up dongle
Hi Carol7,
Welcome to the forum and thanks for posting.
If the BT Mobile Broadband Pre-Pay SIM has never been used it won’t become dormant.  The SIM will become dormant if it has been used at least once, but not for a period of 90 days.  The SIM can be re-activated by you by topping up your account or by using the account if it has existing credit.
BT can switch off accounts which haven't been used for a straight 180 day period (ie: no usage at all for 180 days).
Hope this helps.
Cheers
Sean
Community ManagerSeanD
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Tags (1)
carol7
Message 3 of 4
Thanks for your help. I understand now!
joecon
Newbie
Message 4 of 4
Is there any way to tell if my SIM has been turned off? I've just topped up my mobile broadband account but the modem won't connect and doesn't show a mobile number anymore. I haven't used it for a while - could well be over 180 days.
Is there a way to reactivate the SIM?
