Dusty-Lanes
Message 1 of 17
True Key face recognition lost
I’ve just upgraded to FTP Superfast from ADSL2 ~2 weeks ago. Today facial recognition login has stopped working on all devices, 2 iPads and 2 iPhones. Error message says No Flow available. Then access is by pass phrase which implies that there will be no updates to other devices..
How can this be rectified without loosing all my passwords?
16 REPLIES 16
albertj
Message 2 of 17
Re: True Key face recognition lost
Is this Face ID to access your device?
Please press the thumbs up if you found my response useful and mark it as a solution if I resolved your query.
Dusty-Lanes
Message 3 of 17
No this is face recognition to access True Key.
Dusty-Lanes
Message 4 of 17
This is just to access True Key. I mentioned broadband upgrade simply because this is a contract change
albertj
Message 5 of 17
Oh ok, sorry.
Can you still use Face ID to access the device?
I had a look online for this error message and can not see any mention of it. You could ask on the True Key community provided by McAfee.
Dusty-Lanes
Message 6 of 17
I’ve never had face recognition to access Apple devices.
albertj
Message 7 of 17
Could you please confirm what Apple Devices, you are using (model) Thanks
Dusty-Lanes
Message 8 of 17
Various ages of iOS devices. Most up to date is an iPad pro 2017/18 ish
albertj
Message 9 of 17
If you login using the password are your passwords there?
Moderator
Moderator
Message 10 of 17
Hi, @Dusty-Lanes welcome to the community and thanks for posting, I found this help article for face recognition problems on the McAfee support pages that might help?
