only2mb
Message 1 of 4
Unable to opt out of BT Fon
Hi,
Looking for advice to opt out of BT Fon. I have created a bt email address and tried to log in at
https://www.bt.com/wifi/secure/statuscheck.do
but continue to get the error below even though I recently changed my password  and know it works ok
  • Authentication failed. Invalid username or password.
Any ideas?
3 REPLIES 3
Message 2 of 4
Re: Unable to opt out of BT Fon
The email address has to be assigned as the login details for the account holders MyBT, as only the account holder can alter the settings.
I cannot remember how this is done, but I think its somewhere within MyBT.
Moderator
Moderator
Message 3 of 4
Hi @only2mb,
Have you tried opting out using your BT ID?
If so, then I can take a look at this for you. You can send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
only2mb
Message 4 of 4
excellent - will give that a go right now.
Many thanks!
