mgatu
Message 1 of 15
Urgent please Help - How to set up parental controls
Can someone please help me with how to set up parental controls? I have tried several times but nothing seems to work. I just want to turn wifi off at night and also for few hours during the day when kids are doing their school work.
Thank you
14 REPLIES 14
imjolly
Message 2 of 15
Re: Urgent please Help - How to set up parental controls
Parental controls are set in MYBT.  does this help
 https://home.bt.com/tech-gadgets/internet/broadband/stay-safe-with-bt-parental-controls-113638872384...
mgatu
Message 3 of 15
I have often kept my parental control activated, and I have been setting up times when I wanted it suspended. But I noticed that my wifi is always on 24/7 every day.
Is there a way that I can turn off my wifi, at night via my BT app?
Keith_Beddoe
Message 4 of 15
mgatu
Message 5 of 15
Thank you for the support.
mgatu
Message 6 of 15
Thank you for your support
mgatu
Message 7 of 15
Good morning, I successfully logged in to bt manager hub to turn off the wifi, I want to turn it on this morning, but I am trying to log in again but I am unable to do so, do I need to reset the box first, though it is still showing a blue light
Keith_Beddoe
Message 8 of 15
If you have turned Wifi off, you will have to connect to the home hub using an Ethernet connected device.
yorkspark
Message 9 of 15
which hub are you using?
i can disable devices and whole wifi through the homehub 5 using settings/bt access control, im not sure if the hh6/smarthubs have the same interface though, one of the more knowledgeable contributors may help?
mgatu
Message 10 of 15
Thanks for this info. Do you use your app to control the Wi-fi? Am not sure if I about this.
