PAG87
Message 1 of 5
Virus protect
BT website states :- " BT Virus Protect was previously called BT NetProtect Plus. From the end of October 2016 BT Virus Protect will include mobile security."
However, I have tried to download it on my mobile several times without success! I obtain an acctivation code but when I try to download it states "Item not found"
Have rung BT, but the person I spoke to knew nothing about it, so was no help.
Anyone else having same problem?
4 REPLIES 4
Message 2 of 5
Re: Virus protect
Yes. If you look through the forum you will find others such as this.
https://community.bt.com/t5/Broadband-Extras-from-BT/mcafee-download-to-android-phone/td-p/1677700
PAG87
Message 3 of 5
Re: Virus protect
Thanks, good to know it's not just me, if nothing else!
Message 4 of 5
Re: Virus protect
It is up to you but I would not put McAfee anywhere near any of my devices. I use the free App, Avast Mobile Security and I have found it very good and unobtrusive.
PAG87
Message 5 of 5
Re: Virus protect
Thanks, will look into that.
