Message 1 of 2
Virus protection
Hi, I have downloaded Norton onto my new laptop. I also get prompts to turn on Microsoft defender Antivirus should I turn this on as well as having Norton or ignore as Norton covers all.
1 REPLY 1
Message 2 of 2
Re: Virus protection
Defender should be off if you are running another antivirus product. If you go into your computer settings "Update and Security"  then click on "Virus Threat and Protection" it should show that Norton is installed and turned on and that Defender is off.
