miller46
Newbie
Message 1 of 2
Voicemai and Call Minder
My BT bill shows I have both Voicemail and Call Minder. Do I need both of them, as they seem to do largely the same things?
1 REPLY 1
-Richie-
Expert
Message 2 of 2
Re: Voicemai and Call Minder
It's not possible to have 1571 (voicemail) and Call Minder at the same time, Call Minder is an enhanced version of the 1571 voicemail service.
As to whether you need them, that depends on your household usage, you can see the comparisons and decide for yourself using the links below, If you do wish to downgrade from Call Minder to the basic 1571 it can be done by the Value or Loyalty team on 0800 800 150, the switch would happen at midnight of the day your order is placed, double check your messages incase you have something important saved, if you decide you don't need either then 30 days notice is required to stop them, there is no charge for ceasing them as they are addons on a rolling 30 day contract.
1571 features and benefits can be found Here
Call Minder features and benefits can be found Here
