Nickleback
Message 1 of 2
Which BT Disc extender for a BT Smart Hub 2 (model 091298) do I need ?
Hi,
I'm having problems with Wi-Fi drop out due to coverage on my new BT Smart Hub 2 - model 091298.
So I need to buy a Wi-Fi disc extender to work with the above but I do not have complete Wi-Fi subscription from BT just normal Halo 1.
I have tried a new BT Disc model 092822 but it would not handshake and work properly, I kept getting blue/red flashing light but dont know if the new disc was faulty or not ?
Which model BT Wi-Fi Disc is the correct one to buy that will work with my BT Smart Hub 2 - model 091298 ?
1 REPLY 1
JohnC2
Moderator
Moderator
Message 2 of 2
Re: Which BT Disc extender for a BT Smart Hub 2 (model 091298) do I need ?
Hi @Nickleback  I've had a look and the Complete Wifi Disc and they can be purchased separately from the Smart Hub 2. There is no specific model numbers for different discs.
cheers
John
