Newbie
Message 1 of 2
Which app do I need to open BT cloud using Endless
I Have just added BT cloud to my account - I use a unix based laptop and am running endless but the BT cloud will not recognise this anyone know wthanks for any help that may be cominghich app I need to make this work? DM
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Which app do I need to open BT cloud using Endless
@denislordm Thanks for posting, the BT Cloud software is compatible with Windows 7, Windows 8 and Windows 10. If you use an alternative operating system like Linux or an older version of Windows then you won't be able to install the BT Cloud software.
You can still access BT Cloud on the web at btcloud.bt.com
