c4rm0
Message 1 of 4
Why is the BTfon and WIFI-X SSIDS still broadcasting after opting out
I have opted out of the BT Wifi product as i have no need to connect to BT hotspots and dont want BT customers using my WIFI/Broadband even if the usage is minimal  and they are on a seperate Vlan/Channel . Even though i opted out the SSID for BTFON / WIFI X is still being broadcast from my BT Smart HUB. There is no options in the Smart HUB to turn these SSIDS off. I phoned BT 3 times and they have been useless they are telling me i have opted out (I know that !!!! i did it through the MYBT page)  but when you try to explain the SSIDS are still broadcasting they are clueless. Will these be removed automatically after a period of time or will i have to factory reset my smarthub ?
3 REPLIES 3
Message 2 of 4
Re: Why is the BTfon and WIFI-X SSIDS still broadcasting after opting out
How long ago did you opt out, it can take up to 28 days to take effect.
c4rm0
Message 3 of 4
Hi Thanks for Reply i opted out yesterday. 28 Days !!! wow and it cant be done quicker
Message 4 of 4
This is BT!
