gibbylinks
Message 1 of 5
MY Huawei P20 Pro insists on connecting to the BT-Fon Wi-Fi 1st, even though my home Wi-Fi and other routers are avaliable with the correct passwords and settings stored.
Is it possible to give it a lower priority when looking for connections?
4 REPLIES 4
Message 2 of 5
Re: Wi-Fi
Welcome to this user forum.
Are you using the BT Wifi app?
gibbylinks
Message 3 of 5
Re: Wi-Fi
I do have it installed yes. But I don't knowingly have it open.
Message 4 of 5
Re: Wi-Fi
If you look at the options in the app, there is one to allow it to give your own home wifi priority over BT Wifi.
So it you leave the app running in the background, it will always give your connection priority. I think that option is normally ticked anyway.
The only other option would be to "forget" all stored BT Wifi connections.
gibbylinks
Message 5 of 5
Re: Wi-Fi
Thanks Keith and yes that option is ticked.
