r0bb0
Newbie
Message 1 of 2
bt cloud logging me off
Have just installed the app but almost every time i click on anything it is logging me off then is not remembering my details so i have to type username and password out in full again. Getting to the point where i will probably not use this app if this keeps happening.
Tags (1)
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: bt cloud logging me off
Hi @r0bb0,
Welcome to the community forum. What device are you using to access BT Cloud?
If you take a look at I’m having a problem with BT Cloud login, you'll find a few suggestion that might help.
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
