mmb1
Message 1 of 7
bt virus protect
my broadband pkg says BT VP is inclusive, thats not strictly true as its starts off free, then becomes chargeable!
surely the online advert info shown to bt users should state all the facts clearly - rather than lure people with mis-leading front screens and reliy on them reading the underlying T&C's!
6 REPLIES 6
Message 2 of 7
Re: bt virus protect
It is free with your package. Why do you think you have to pay for it?
Message 3 of 7
UPDATE:
It would appear that BT have changed the way they offer BT Virus Protect.
It used to be 2 free licences with Infinity 1 and 15 free licences with Infinity 2
It appears that it is now only free for the first month and £4 a month there after.
https://www.productsandservices.bt.com/products/manage-broadband-extras#stay-safe-online-with-netpro...
"What does it cost?
It's £4 a month with the first month free if you've got Broadband, Unlimited Broadband, Infinity 1 or Unlimited Infinity 1"
There are plenty free Antivirus programes avaiable such as Avast that are rated higher than BT Protect/McAfee so I would suggest that you uninstall BT Antivirus and use one of the free ones.
mmb1
Message 4 of 7
Avast for virus protection, what about malware?
Message 5 of 7
MalwareBytes
Moderator
Moderator
Message 6 of 7
Hi Everyone,
I'm sorry for any confusion caused, BT Virus Protect with two licenses is still free for customers on standard broadband or Infinity 1. However customers with the two-license BT Virus Protect can upgrade to 15 licenses for £4 a month and as part of our special offer, they'll get the first month free if they decide to upgrade to the 15 license version.
Message 7 of 7
@NeilO wrote:
Hi Everyone,
If that is the case I think the web site needs a bit of a re-vamp. It presently does not make it clear that the £4 is to "upgrade" to 15 licences.
What does it cost?
