andrewmorris
Message 1 of 7
bt wifi app
Hi. Having problems getting bt WiFi app to work on new phone. getting "unknown error" message. Have reinstalled, refeshed cache and checked log in details. I also get a not registered for access message if I try to log in through landing page. Has worked perfectly on old phone so wonder about Compatability...
Is there a comparability issue with an LG g3s running android 4.4.2?
6 REPLIES 6
Moderator
Moderator
Message 2 of 7
Re: bt wifi app
Hi andrewmorris,
Are you using your BT ID or your email details to log in as this could be the problem?  Check out this link What's my BT Wi-fi password or username? and let us know if this helps.
Neil
andrewmorris
Message 3 of 7
Re: bt wifi app
Hi neil. I have checked my username by logging into mybt, and it is right. I took the option recently to change the id to my hotmail address, but even so, it continued to work on my old phone. I have tried several times, and occasionally get a different error message which implies that i am not signed up to bt wifi, but again have checked my account (and it worked on my old phone)
andrewmorris
Message 4 of 7
Re: bt wifi app
I guess this means no one has any other ideas?
Distinguished Guru
Distinguished Guru
Message 5 of 7
Re: bt wifi app
Have you tried logging in with your original btinternet.com address? As I understand it, other usernames don't work with BT WiFi even if they do with MyBT. It's never been joined up all that well.
Message 6 of 7
Re: bt wifi app
For new users to BT to log onto BTWifi I believe that you need to use an @btinternet.com email address and that email address must be the same as your MyBT - BTID.
This is to make your BTID the same as your MYBT and BTWifi log on details so that you can access all the BT services through your MyBT.
See link
http://bt.custhelp.com/app/answers/detail/a_id/45822/~/what-is-a-bt-id-and-how-can-i-get-one%3F
To change your BTID you need to access your "MyProfile" in MYBT. Go to "My Contact Details" and change the email address to a @btinternet.com one and then go to "My Security" details and change the password to the same as you use to log into your email. This will make your BTID and password the same for all the BT services such as BTWifi and BT Sport.
You also need to make sure that your BTID is the primary BTID for that account.
I suspect the reason that your old phone works is because it has retained the old log on details in its cache.
You can check your BTWifi status here
https://www.bt.com/wifi/secure/index.do?s_cid=con_FURL_btfon
andrewmorris
Message 7 of 7
Re: bt wifi app
Hi, i reset my primary btid to the original btinternet.con one, then emptied the cache (as you mentioned the old phone working because if the cache) as it didnt work straight away. But it does now. Thanks!
