philwill
Message 1 of 6
casting issue with BT sport app
Hello. First time I`ve used so will try & explain as simply as possibe.
I have apple iphone & ipad which I have used to cast bt sport app to my sony android tv - this has casting built in.
Never had an issue until recently but all of a sudden tv not recognised when trying to cast!
ios up to date/ have up to date casting app on tv/ have tried soft reset / bt app up to date too
Help appreciated.
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: casting issue with BT sport app
Hi @philwill  and welcome to the community.
Sorry you're having problems casting. Can you confirm if this is only and issue with the sport app or are you having problems casting in general?
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
philwill
Message 3 of 6
Hello. This is the only issue with the app!
Moderator
Moderator
Message 4 of 6
Hi @philwill  Thanks for getting back to us. Check out Setting up the BT Sport App on smartphones and tablets and see if that helps.
If you still cannot cast let me know if you have the BT Sport on BT Mobile or the full BT Sport App with BT Broadband.
cheers
John
Community ModeratorJohnC
Kudos”
philwill
Message 5 of 6
Hello & thanks. I have bt sport app & bt broadband. Have been using without issue for over a year but suddenly unable to cast. I’ve not changed any settings & all software is up to date. Regards
Moderator
Moderator
Message 6 of 6
Hi @philwill  thanks for getting back to me to confirm that. We will be happy to help you with this. I've sent you a Private message explaining how you can contact the forum moderation team.
Check here: https://community.bt.com/t5/notes/privatenotespage
cheers
John
Kudos”
