Message 1 of 8
critical error
Hi - I posted the following information back in June of last year and no-one ever got back to me with a reply.  I still have the same problem arising.  When I check my action centre under maintenance I view the reliability  history section where I regularly get the following error message - can anyone please tell me what this is about?
A problem caused this program to stop interacting with Windows.
Faulting Application Path: C:\Windows\System32\backgroundTaskHost.exe
Problem signature
Problem Event Name: MoAppHang
Package Full Name: BRITISHTELECOMMUNICATIONS.BTWifi_1.3.0.0_x64__p4cqfe0ssz2sj
Application Name: praid:App
Application Version: 6.3.9600.17415
Application Timestamp: 545042b7
Hang Signature: 67ad
Hang Type: 8388864
OS Version: 6.3.9600.2.0.0.768.101
Locale ID: 2057
Additional Hang Signature 1: 67ad30cc3beafa7f6b551ae428c8c759
Additional Hang Signature 2: 44f5
Additional Hang Signature 3: 44f5720d37721306a7736d4c15ee9419
Additional Hang Signature 4: 67ad
Additional Hang Signature 5: 67ad30cc3beafa7f6b551ae428c8c759
Additional Hang Signature 6: 44f5
Additional Hang Signature 7: 44f5720d37721306a7736d4c15ee9419
Extra information about the problem
Bucket ID: 9438f69a42bd5fa42a0333890846e660 (98886852527)
7 REPLIES 7
Message 2 of 8
Re: critical error
Do you have the BTWifi app installed on your device or any other BT app. It looks like it is a BT app that is crashing. If you do have a BT installed try uninstalling and reinstalling it.
Message 3 of 8
Re: critical error
Thanks for your help - I did have a wifi app and have uninstalled it but have not re-installed it as yet but will try and do this after a few more days of being free of this error.  I will let you know what happens when I reinstall the app.  In the meantime I have another critical error which I hope you can also help me with as follows:-
Faulting Application Path: C:\Program Files\WindowsApps\BooStudioLLC.FilesFoldersLite_1.1.0.16_x86__b6e429xa66pga\commander.exe
Problem signature
Problem Event Name: MoAppCrash
Package Full Name: BooStudioLLC.FilesFoldersLite_1.1.0.16_x86__b6e429xa66pga
Application Version: 0.0.0.0
Application Timestamp: 54fef1cd
Fault Module Name: clr.dll
Fault Module Version: 4.7.3362.0
Fault Module Timestamp: 5c2fd0c9
Exception Code: c0000005
Exception Offset: 001062ad
Locale ID: 2057
Additional Information 1: ebd3
Additional Information 2: ebd3e37a358446d9bb548c1433c4c342
Additional Information 3: d884
Additional Information 4: d884114be74292bb73e2d906a4231bd8
Bucket ID: eb5de46b1c10b60b06195bb40003c561 (1592404771904669025)
Thanks again for your input
Distinguished Guru
Distinguished Guru
Message 4 of 8
Re: critical error
There seems to a similar issue raised in microsoft  forum where some advice  was given by one of their volunteer moderators. Perhaps that could help
https://answers.microsoft.com/en-us/windows/forum/all/critical-error-windows-81/6251a7b1-39d0-4edc-9...
Message 5 of 8
Re: critical error
The error you have now appears to be from an app from BooStudio. It may be a torrent downloader and may be a piece of malware.
I would run a malware scan on the computer and see what it picks up. If the malware scanner shows all clear you could try running sfc /scannow as indicated in the post by Zulu17 which should help detect any corrupted system files that could be causing the errors.
Moderator
Moderator
Message 6 of 8
Re: critical error
Hi @cj3 and welcome back. It's been while since your last visit but it's great to see you again.
We're keen to learn about these types of problems so can you let me know if you've followed @gg30340  and @zulu17  advice and if it helped?
David
Message 7 of 8
Re: critical error
the sfc / scannow did not show any problems and I do not have any malware.  I deleted an app and a few folders that I thought could be a problem.  I have had no problems over the last few days but if the problem re-appears that I will perform a clean boot as you suggested.  Thanks for your help.
Moderator
Moderator
Message 8 of 8
Re: critical error
Good morning @cj3 ,
Thanks for getting back to me, it's really appreciated. It sounds like you've got this sorted so I'll mark it as solved but if you do have any problems please post back and we'll be happy to lend a hand. Thanks again to @gg30340 and @zulu17 for helping out.
Cheers
David
