Zcott
Message 1 of 4
iOS Profile
In the FAQs of the BT wifi app it says I can install the connection profile from the help and support button. However, there's no sign of a profile installer there. Has this functionality been removed but references to it left?
Tags (4)
3 REPLIES 3
Message 2 of 4
Re: iOS Profile
If you download the app from the itunes store it is very easy to setup. You only need to enter your primary email address and password.
Zcott
Message 3 of 4
Re: iOS Profile
So there's no profile to install? Will my device connect automatically to the BT Wifi hotspots?
Message 4 of 4
Re: iOS Profile
There is no profile to install. Once installed on your phone you just need to enter your primary email address and password. When you are in range of a BTWifi hotspot it will log on automatically. If you go into the settings on the app you can set it to notify you by sound and vibrate once connected.
I use an Android phone and it works without a problem so I would imagine it will be the same on your iPhone.
