Message 1 of 2
norton security
I have just moved to Norton as advised by BT but can no longer see a prompt to shred files. I used to be able to do this with McAfee by simply right clicking a file and pointing to shred.
Can anybody advise whether this is available on the Norton download that BT have provided.
1 REPLY 1
Message 2 of 2
Re: norton security
Norton i don't use it becuse it used to slow down your pc i just use windows 10 security it can shred files
i only used norton once i just uninstall it becuse you get the same stuff from windows 10 security unless they fixed that issue with slowing down the pc i maybe start using norton has it done auto i thing or in advenced setting within norton there maybe a sherd option
