bobsthedog
Message 1 of 6
re bt tv app
I recently downloaded the BTTV App but when I try to log in I get "sorry there is a problem with your account error TVE-A931. I have the right password as it works on BTSport
5 REPLIES 5
Moderator
Moderator
Message 2 of 6
Re: re bt tv app
Hi @bobsthedog and welcome.
I'm sorry you're having problems with the TVE-A931 error message. If you haven't managed to resolve this can you please drop me over an email with your details and I'll look into it for you. You'll get the contact the moderators link in my profile.
Cheers
David
Moderator
Moderator
Message 3 of 6
Re: re bt tv app
Hi @bobsthedog,
Thanks for sending over the details. I tried calling this morning, sorry I missed you. I've raised this to our product support guys and will be in touch as soon as I have any updates for you.
Cheers
David
Moderator
Moderator
Message 4 of 6
Re: re bt tv app
Hi @bobsthedog,
I tried calling today, sorry I missed you. I've had notice that this should now be sorted so can you check and post back?
Cheers
David
bobsthedog
Message 5 of 6
Re: re bt tv app
Thanks a lot Mark it seems to be working as it should many thanks
Moderator
Moderator
Message 6 of 6
Re: re bt tv app
Thanks for getting back @bobsthedog. I'm glad to hear this is sorted. I'll close things off from my side but if you have any other problems please post back and we'll be happy to help.
All the best
David
