Shainia
Newbie
Message 1 of 2
smarttalk app for android marshmallow phone
I have been trying to install the smarttalk app on my android marshmallow phone. I keep getting a message saying, "not available in your country". I would appreciate some help please?.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: smarttalk app for android marshmallow phone
Hi @Shainia Sorry you are having a problem setting up the SmartTalk service.
Try this Fix problems signing up to BT SmartTalk and there is a link to Live Chat if you still need help to set up the service.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
