TEG33
Message 1 of 5
wifi hotspots
How many devices can you use the BT WIFI hotspot on when in the same  location , using the same login details ?
4 REPLIES 4
Message 2 of 5
Re: wifi hotspots
Don't think there is a limit.
Message 3 of 5
Re: wifi hotspots
There is no limit. Keep in mind that who ever you give the log onto details to will have access to your MyBT and ultimately to any email accounts that are linked to that.
You will also be sharing limited bandwidth so don't expect great speeds.
TEG33
Message 4 of 5
Re: wifi hotspots
Many thanks for the replies, was a bit bothered as my daughter have just ordered Bt Infinity 1 and landline ,but it will not be up and running for 4 weeks as BT say they are  very busy ....the 2 children will need WIFI in the mean time else they will go up the wall so hearing they can both use their i-pads iin the interim is helpful .
Should the wifi be poor in the bedrooms after the Infinty 1 set-up ( cannot rig the router anywhere else bar downstairs),do these wifi extenders actually do the job ?
Message 5 of 5
Re: wifi hotspots
Yes.
See link
https://www.shop.bt.com/mini-sites/connected-home/broadband-extenders/
You do not need to use BT ones so it might be worth shopping around.
