alecst
0
BT WiFi with fon
I'm trying to log into a WiFi hotspot using my bt username & password, but it's not recognised. Is there a seperate username & password to use fon?
Distinguished Guru
gg30340
0
Re: BT WiFi with fon
[ Edited ]
No it is your primary email address and password. It is case sensitive so make sure you are entering it correctly. I say this because you when  you log into your email it BTYahoo it is not case sensitive. Also make sure you are using the BTWifi BT broadband customer login part.
See these links for further help
http://community.bt.com/t5/BB-Out-About/BT-Wi-Fi-issues/td-p/697978
http://www.btwifi.com/help/login-with-bt/index.jsp
"If you want to say thanks for a helpful answer, click the white star"
Distinguished Guru
pottyperson
It is when I try it, gg.
[I'm moving this thread to the BB Out & About board, the right place for it.]
You can click the white star next to this message if you think it was helpful.
Distinguished Guru
gg30340
0
I stand corrected. I am sure I used to be able to log in in either case but I have just tried it and you are correct.,it is case sensitive.
Sage
imjolly
I think that is the problem with the ipad as I just tried mine and it capitalises the first letter of the sign in so when you try and login to BTWIFI it fails - change to lower case and sign in complete
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
Guru
AllanQuatermain
0
Im sure it wasnt case sensitive in the past as well; could be in the pre wi fi app [update] days maybe?.........
or just poor memory on my part [and gg]. :smileysad:
AQ.
"Welcome to Royston Vasey - You'll never leave."
Distinguished Guru
DS
0
Now I always thought that it was case sensitive:smileyindifferent:
It was just on some devices you didn't need @btinternet.com as part of the username, just the first part of it (firstnamelastname)
-+-No longer a forum member-+-
