Geoff2474
0
Logging onto Fon and/or broadband
Hi. I am new so please be gentle with me.
Sitting in my car with laptop and good WiFi set up, I find loads of good Openzone and Fon sites. I can log into the openzone sites but every time I try a Fon site it says your username or password is incorrect????????
I must be missing something as I was under the impression that the log-in details were the same.
Also if I try to log-in to 'MY BT' I also get the same message.
I have no trouble logging into BT Yarhoo with the same details.
HELP please
Sage
imjolly
0
Re: Logging onto Fon and/or broadband
have you set up a My BT account if you not you need to set one up and need not necessarily use the same email address and password.
If you like a post, or want to say thanks for a helpful answer, please click on the Ratings star on the left-hand side of the post.
WatchdogTS
0
I think the catch is you have to register for online billing so you need to do what imjolly suggests.
Sage
john46
0
you need to log in using your BT email address and password
If you want to say thanks for a helpful answer,please click on the Ratings star on the left-hand side If the reply answers your question then please mark as ’Mark as Accepted Solution’
