tim11
0
Accepted Solution
bt wifi login
Hi,have btbroadband opt 3. Can't login to bt WiFi as says user/password invalid but can access mail ok with same details. Also registration page says im bt yahoo homemover? And opted out. If try to re-register always says server busy.
Sage
john46
0
Re: bt wifi login
Hi the log in is your master BT email address and password
If you want to say thanks for a helpful answer,please click on the Ratings star on the left-hand side If the reply answers your question then please mark as ’Mark as Accepted Solution’
tim11
0
Re: bt wifi login
I already use the master email address and password to access mail so its not that.
Guru
AllanQuatermain
0
Re: bt wifi login
On the Fon homepage, make sure you are signing in/signing up as a BT BB customer, using the id you mention.
When you are signing in, you sign in as a BT BB Customer category, not Fon customer or any other third party.
There is of course the android/apple/blackberry app available which does this auto on a smartphone.
AQ.
"Welcome to Royston Vasey - You'll never leave."
tim11
0
Re: bt wifi login
Hi Allan,
I use the same details as my Yahoo mail login but this does not work.
Plus the register for Wifi page always show server busy ! please try later but It's always like this.
Guru
AllanQuatermain
0
Re: bt wifi login
Hi tim11 I will try and simulate this scenario and post back.
AQ.
Distinguished Guru
DS
0
Re: bt wifi login
I'd say there's an issue with you BT BB account.
Have you called BT and checked to see if there's a home move note on your account?
-+-No longer a forum member-+-
Guru
AllanQuatermain
0
Re: bt wifi login
[ Edited ]
OK, I've managed to check my BT wi Fi [Fon] status no problem via the page on the link below. Can you get no further than the error message you mention in your post? If you get stuck here; then I agree with DS.
https://www.bt.com/wifi/secure/status.do?s_cid=con_FURL_btfon/status
AQ.
tim11
0
Re: bt wifi login
Hi,
Moderator Stephanie Guabello has kindly solved the problem for me, seems when I had landline number changed I was given a new Primary email address even though I continue to use my old one.
So now I can access Wifi with the other email address and a reset password.
Thanks everyone.
Regards
Newbie
Lazyfist
0
Re: bt wifi login
Wonder if I have same problem try to register bt wifi with yahoo I'd but won't let me
