Newbie
trevor6832
0
Accepted Solution
mobile wifi not connecting after password change
Hi y'all!
I've just changed my email password and that's working fine as far as logging into BT Yahoo and sending / receiving emails is concerned. However, when I changed the opassword in the WiFi app on my Android phone I just get an error message saying "There has been an error whilst trying to opt youin. Please try again later". Anybody know how to fix this? Thanks. Trevor.
Distinguished Guru
DS
0
Re: mobile wifi not connecting after password change
Hi trevor6832 and welcome to the forums
You'd be best to uninstall the app, then re-install it, fill out the details (with the new password) and see if it now works
-+-No longer a forum member-+-
Newbie
trevor6832
0
Hi, Thanks. In the end I phoned BT and they said the Yahoo server was down, apparently its that that controls the passwords and login, and would be fixed in 4 hours. Sure enough it worked OK after that.
