Do you mean
Accepted Solution
BT NETPROTECT PLUS
Just had an update downloaded of Mcafee net protect plus.   Every time I try to go into BT Netprotect plus is says updates have been dowloaded and to restart computer.  Have done this no effect.  Even did system restore to before updated and downloaded the update again, still asking me to restart computer which I have done.  Any solutions.  Am not technical with this at all
Re: BT NETPROTECT PLUS
Problem solved by tech support.  had to remove and reinstall
i had net protect with my last comput erhow can I ge it now I have the same broadbond and email address
Distinguished Guru
Hisilverlilac7 and welcome
Please read this - http://bt.custhelp.com/app/answers/detail/a_id/12640/c/346,510,2164
-+-No longer a forum member-+-
