Do you mean
Newbie
Problems regarding online gaming - Strict NAT Type - Tried everything
Hey there, I'm currently using BTHomeHub2, and I have a wireless connection for my PS3.
Currently, I've encountered a problem while playing Call of Duty - Black Ops. I've recently discovered that my NAT Type is strict, which sort of made sense, as I could barely ever hear team chat, and found it hard to join matches.
Now, what I've tried:
I've tried disabling Firewall.
I've put the PS3 into DMZ mode, which only gave it DNS problems.
I followed the steps on BT's help page, which suggested giving the PS3 one IP, which didn't work.
The PS3's IP in unique from others on the network too.
Tried disabling DHCP to give all devices a static IP, but this caused problems.
I'm tearing my hair out guys :/
Anyway, I gave Port Forwarding a shot, but I'm not [i]that[/i] technical. My NAT Type is 2, which is generally regarded as 'good'.
Anyway, best wishes, hope someone can help me Smiley Happy
-Ben
Re: Problems regarding online gaming - Strict NAT Type - Tried everything
Recognised Expert
[ Edited ]
You might be lucky with portforward, however if it goes the way many have posted here with problem, i would forget Cod series on the Ps3, check the link.
http://uk.videogames.games.yahoo.com/16/news/black-ops-reported-to-office-of-fair-trading-21be16.htm...
Mortgage Advisor 2000-2008
Green Energy Advisor 2008-2010
Charity Health Care Provider Advisor 2010-
I'm alright Jack....
I had the same problem but found one way around this problem  but you will need a modern warfare 2 disc.
What you do is load black ops check your nat type eject the disc while the game is at the menu screen, now put
your mw2 disc in straight away load it up go to multiplayer and check nat type it should be open, now eject the disc and reload black ops now check your nat type it should be open.
It is a lot of hassle but once done it should stay open unless there is new up dates etc or your hub is reset.
I would agree about it.. If you want to use the PS3 online I would say use the ethernet connection and not the WiFi.. I had a PS3 since day one and on WiFi is very very slow and drops connections. Hey and I am not even with BT yet ... The moment I plugged in the cable it works fine althought I am not a online gamer but tried once or twice huge difference..
Newbie
Re: Unable to play Black Ops on PS3
If you are suffering with your NAT type being strick the same as i was, put in a copy of MW2 let it load up then put black ops back in, i know it sounds daft but it worked for me, hope it does for you
Newbie
Go online to find experts that may guide you step by step.These men online may show you how to fix your console just as an experienced repairman would fix it.
All these errors can be fixed completely by you without the involvement of any external agency.
Disassembly
1.PS3 Disassembly
2. PS3 Controller Disassembly
 Fix Common Problems
Fix to all update related problems
1. The Mystery of the Blinking PlayStation 3
2. The dirt on Blu-ray lens (and how to clean it)
3. PS3 Owners Report Blu-ray Problems After 1.5 Upgrade
4. PS3 Bluetooth Controller Issues
5. Playstation 3 HDMI Problem and Fix!
6. Display/Video Fixes
7. PS3 Error Codes (With related fix)
8. How to Change From HDMI > Composite Easier
9. PS3 3 Beep & Blinking Red Light Fix
 PS3 Modifications
1. PS3 3.5" SATA HDD Mod
2. Adding IR Remote Control to the Sony PS3
3. PS3 HDD Replacement Mini-Guide
4. USB Flash Memory, USB Hard Drive (External Use)
 Controller Modifications
1. PS3 Controller Light Mod
2. PS360: Microsoft Controller, Meet Sony Controller
3. PS3 Controller Light Mod 2
4. PS3 Controller Button Contacts, Add extra buttons to the PS3 controller
 Other Modifications
1. Charging Station Headset Mod
 Blu-Ray
1. Decrypt Blu-Ray Movies with a PS3 WITHOUT keys
2. Blu-Ray Unique Volume Keys
3. Blu-Ray Media Links
4. Play BluRay movies without disk
5. Convert HD-DVD To Blu-ray (works On PS3), No Loss Of Quality
 Other Media/Video
1. Set up media servers for your PS3
2. Transfer files from PC to PS3 via WmP11/Nero (via DLNA/MediaServers)
3. How to stream AVI files on PS3 via Tversity
4. Copy music/videos from your iPod to PS3
5. Getting your PS3 to recognize your External Hard Drive
6. How to create a PS3 HD-MPG from HD-TS (Best Result For Below 1.6FW)
7. How to install your game saves
8. Downloading PS3 Game Saves
 Audio
1. How to connect PS3 to PC speakers
1. How to change from 'NAT type 3' to 'NAT type 2'
2. Make a Lag Switch
3. Who Needs SIMPLE DNS
4. Remote Play On-The-Go
 Playstation Network
1. PSN Game Sharing Instructions
2. How to download Japanese Demos/Create Jap PSN account
3. Create Different Region PSN Accounts
4. View PS3 Store, Download Demos on your PC and install Demos To PS3
5. Play Online And Access Sony Store No Updating
6. View Playstation store on PC
 Firmware Modifications
1. PS3 Firmware Version Check Bypassed (Linux)
2. PS3 Firmware Version Check Bypassed (Windows)
3. Ettercap Windows
4. PS3 Demonstration Mode "Unlock" Code
5. Use SIMPLEDNS To Bypass The Firmware Check (Windows)
6. How to UPDATE your PS3
 Linux
1. How to install Fedora Core 6 Linux for PS3
2. PS3 Linux - The void has been filled...Full install instructions for Fedora Core 5
3. PS3 Linux FAQ
4. GUI Kboot
5. Yellow Dog Linux Free Version
6. Yellow Dog Linux 5.0 Installation
7. Partitioning and readying your PS3 for Linux
8. Gentoo
9. Uninstalling Linux
10. Installing YDL+VLC+Mplayer+Snes9x
11. Installing Mplayer on PS3
12. Installing VLC player on PS3
13. Installing "Other OS" on PS3
14. How to get Wi-Fi to work with YDL
15. Set up a Linux UPnP media server w/PS3 support
16. Run Ubuntu Linux 7.04 (Feisty Fawn) on PS3
17. Ubuntu, Kubuntu, Xubuntu, and Edubuntu onto a PlayStation 3
18. Emulate WinXP in PS3 under Linux
 Downloads
1. Homebrew Loaders
2. Linux
3. Utilities
4. Firmware Updates
5. "Other OS" Bootable Homebrew
6. Drivers
7. Proof-Of-Concept Exploits
8. Game Saves
 PS2/PS1 on PS3
1. Do your PS2 games look too jaggy on the PS3? Here's a semi-fix...
2. PS3 SWAP to play PS2 and PSX Games!
3. How to play/install to play PS2 backups on PS3
1. PS3 Features
2. Finding RAM locations on resistance
3. PS3 Parental Controls How-to
5. PS3 BiOS Flash Diagram Rev 1.0
So, if you have experienced some of the errors in your console, it is not the end of your gaming days, you can fix it. There are many solutions out there if you are willing to do a little research.
This guide most possibly will contain the solution to the problem you have encountered.
Ps3 repair guide
Good luck, and happy gaming.
Newbie
Ps3 errors- How to DIY
Disassembly
1.PS3 Disassembly
 Fix Common Problems
 PS3 Modifications
 Other Modifications
 Blu-Ray
 Other Media/Video
 Audio
 Playstation Network
3. Ettercap Windows
 Linux
3. PS3 Linux FAQ
4. GUI Kboot
8. Gentoo
 Downloads
1. Homebrew Loaders
2. Linux
3. Utilities
4. Firmware Updates
6. Drivers
8. Game Saves
 PS2/PS1 on PS3
1. PS3 Features
Ps3 repair guide
Newbie
Re: Ps3 errors- How to DIY
this happened to me on the xbox but i just removed my internet from the xbox then reconnected it and it worked Smiley Happy
Strict NAT
I have Home Hub 2.0
When playing Dead Space 2 Multiplayer on PC I always notice that my NAT Type is set on strict and that I hardly ever find any games since I cannot connect to many other players.
How do I set my NAT type to open?
