Message 1 of 4
App pairing to tv pro box
Quick question, can you pair 2 phones to the new pro box?
Set up my phone, everything worked first time, scheduled recordings etc , just a second phone would allow other half to set recordings as well
3 REPLIES 3
Message 2 of 4
Re: App pairing to tv pro box
Yes you can pair several devices , from memory believe the limit used to be ten.
Message 3 of 4
thank you
Message 4 of 4
2 apps now paired and all working fine
