Message 1 of 5
BT TV Box Pro FreeView
Should FreeView be listed with the Apps on the BT TV Box?
4 REPLIES 4
Message 2 of 5
Re: BT TV Box Pro FreeView
No because BT TV runs Youview software and not Freeview Play. The Freeview channels are listed in the EPG
Message 3 of 5
Many thanks for your reply but what is the EPG?
Anonymous
Not applicable
Message 4 of 5
Electronic Programme Guide.
Message 5 of 5
Many thanks for explanation
