Peterryanhome
- Mark as New
- Bookmark
- Subscribe
- Subscribe to this message's RSS Feed
- Highlight this Message
I am trying to setup a new BT TV pro box . It should give a choice of wired or wireless connection during setup but it is defaulting to wired and won't let me move off that screen. How do i get the Wi-Fi setup option?
Solved! Go to Solution.
0
Ratings
2 REPLIES 2
Keith_Beddoe
- Mark as New
- Bookmark
- Subscribe
Re: BT TV Pro box setup
Peterryanhome
- Mark as New
- Bookmark
- Subscribe
Thanks for the responses. I did connect the box via Ethernet . It did an update and finally the product matched the instructions in the box. So wireless now working. So it seems that the instructions should be - first-time connection must be via Ethernet to the hub. This will allow the box to gets the latest software update. Then you can go into BT Tv , select settings and change the connection to wireless.
0
Ratings
