Message 31 of 55
Re: Bt pro box unable to set record for 1day
Its to do with the update
Message 32 of 55
Re: BT Pro box 'ghost' failed recordings
Same here!
Message 33 of 55
Same here
Message 34 of 55
Just to say if you are not able to set up Freeview recordings in advance today (march 1st)  I am noticing that once the program starts I am able to record ( ie the current broadcast programme in the guide appears to record)
Message 35 of 55
I found another quirky work around tonight.
I wanted to record The Holiday on 5HD which started tonight at 9:00. Just after 8:00 (during half-time of the Peterborough/City game) I was able to select The Holiday in the EPG and press record. The little red R came up in the EPG but it did not appear in the Scheduled section of MyTV. At 9:00 it started recording.
Go figure!
Message 36 of 55
Same thing happening on mine too now
Message 37 of 55
Still failing to record pgms scheduled for tonight. This is despite following all recommendations.
One recording (The Chase, actually come up at 18:01, as starting recording, when the pgm had finished.
Spme recordings still think they are scheduled for Friday, instead of today.
Obviously a calendar pb with the Pro Box (doesn't appear on others I believe?). I worked in IT, and scheduling for many yrs, and it is paramount calendars are checked before the start of the new year.
There are so many sub-issues with this box, and it's software, it would seem to me it was rolled out in advance of Sky Glass to gain a march, without full Beta testing. V poor all round.
Surround sound issues, calenday issues, blue tooth issues (only works on unblocked line-of-sight.
Message 38 of 55
@scharter  With the The Chase recording  is it possible that your box has recorded it from the ITV+1 channel ?
Message 39 of 55
Hi @zulu17  Just checked,  and yes it was recording the +1 channel, which is really odd, as the realtime pgm has been on 'series record' for months. The Pro Box decided itself to record the +1 pgm, without any input from me.  Something strange going on.
Message 40 of 55
