Message 1 of 7
Major update
ok so my HD channels went missing this morning along with unable to record . Spoke to a guy he did a full reset that deleted everything then lunchtime today 1/3/22 channels went missing so I did the reset what you have been telling people to do that worked . Then tea time today all my HD channels went . So again I spoke to a gentleman that was not aware of any update and wanted to send me an engineer! Unbelievable right . I said I don't want an engineer this is due to an update. He was oblivious to it...... It all went quiet then.... He got back to me and said the update which he was not aware of told me it will take up to 48 hrs.... So thats that then . ...oh hi everyone.
6 REPLIES 6
Anonymous
Not applicable
Message 2 of 7
Re: Major update
You might want to check out this post.
Message 3 of 7
Re: Major update
Cheers stereo just done that but no joy
Anonymous
Not applicable
Message 4 of 7
Re: Major update
Hold tight then, the update has just started rolling out by the sounds of it 👍
Message 5 of 7
Re: Major update
Hey yup I'm on did the aerial out TV cable out put TV cable back in then followed by the aerial and bibs your auntie . Lets see how long for.
Message 6 of 7
Re: Major update
New Update not fixed problem Still no NOW channels and date showing 4th March
Message 7 of 7
Re: Major update
Timm mine is fine at the moment try and do the basic reset aerial out power cable out put power cable back in then wait and then put the aerial cable back in
